systemctl restart logrotate
Job for logrotate.service failed because the control process exited with error code.
See "systemctl status logrotate.service" and "journalctl -xe" for details.
root@host:/var/log# grep logrotate /var/log/syslog /var/log/auth.log
/var/log/syslog:May  1 00:00:00 host systemd[1]: logrotate.service: Main process exited, code=exited, status=1/FAILURE
/var/log/syslog:May  1 00:00:00 host systemd[1]: logrotate.service: Failed with result 'exit-code'.
/var/log/syslog:May  1 19:57:49 host logrotate[1042123]: error: error renaming /etc/httpd/vhost_logs/s.xxxx.ru_access.1.gz.10.gz to /etc/httpd/vhost_logs/s.xxxx.ru_access.1.gz.11.gz: Read-only file system
/var/log/syslog:May  1 19:57:49 host systemd[1]: logrotate.service: Main process exited, code=exited, status=1/FAILURE
/var/log/syslog:May  1 19:57:49 host systemd[1]: logrotate.service: Failed with result 'exit-code'.
