У вас нет лицензии
ivanpetrov
Re: У вас нет лицензии
Сообщение ivanpetrov » Чт мар 20, 2025 10:05 am
root@thishosting:~# cat /etc/resolv.conf
# This is /run/systemd/resolve/stub-resolv.conf managed by man:systemd-resolved(8).
# Do not edit.
# This file might be symlinked as /etc/resolv.conf. If you're looking at
# /etc/resolv.conf and seeing this text, you have followed the symlink.
# This is a dynamic resolv.conf file for connecting local clients to the
# internal DNS stub resolver of systemd-resolved. This file lists all
# configured search domains.
# Run "resolvectl status" to see details about the uplink DNS servers
# currently in use.
# Third party programs should typically not access this file directly, but only
# through the symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a
# different way, replace this symlink by a static file or a different symlink.
# See man:systemd-resolved.service(8) for details about the supported modes of
# operation for /etc/resolv.conf.
nameserver 127.0.0.53
options edns0 trust-ad
search .
root@thishosting:~# traceroute panelname.shn-host.ru
Command 'traceroute' not found, but can be installed with:
apt install inetutils-traceroute # version 2:2.4-3ubuntu1, or
apt install traceroute # version 1:2.1.5-1
root@thishosting:~# traceroute panelbr1.shn-host.ru
root@thishosting:~# traceroute panelbr2.shn-host.ru
root@thishosting:~#
Сообщение alenka » Чт мар 20, 2025 10:07 am
apt-get -y install traceroute
В резолвере долны быть сервера гугла
nameserver 8.8.8.8 больше ничего
ivanpetrov
Сообщение ivanpetrov » Чт мар 20, 2025 10:11 am
root@thishosting:~# apt-get -y install traceroute
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
cron-daemon-common libintl-perl libintl-xs-perl libmbim-utils libmodule-find-perl libmodule-scandeps-perl libproc-processtable-perl
libqmi-utils libsort-naturally-perl libssl1.0.0 libtcl8.6 tcl tcl8.6 usb-modeswitch usb-modeswitch-data
Use 'apt autoremove' to remove them.
The following NEW packages will be installed:
traceroute
0 upgraded, 1 newly installed, 0 to remove and 8 not upgraded.
Need to get 60.5 kB of archives.
After this operation, 162 kB of additional disk space will be used.
Ign:1 http://de.archive.ubuntu.com/ubuntu noble/universe amd64 traceroute amd64 1:2.1.5-1
Err:1 http://de.archive.ubuntu.com/ubuntu noble/universe amd64 traceroute amd64 1:2.1.5-1
Temporary failure resolving 'de.archive.ubuntu.com'
E: Failed to fetch http://de.archive.ubuntu.com/ubuntu/poo ... _amd64.deb Temporary failure resolving 'de.archive.ubuntu.com'
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Сообщение alenka » Чт мар 20, 2025 10:15 am
У вас проблема с сетью на сервере, вы в резолвер прописали неймсервера гугла?
ivanpetrov
Сообщение ivanpetrov » Чт мар 20, 2025 10:19 am
Я не написал. Но сейчас убрал. Теперь он такой.
/run/systemd/resolve/resolv.conf
nameserver 8.8.8.8
#nameserver 1.1.1.1
#nameserver 8.8.8.8
# Too many DNS servers configured, the following entries may be ignored.
#nameserver 1.1.1.1
#search .
А файл не трогал:
search .
Там надо убрать строку search . ?
Сообщение alenka » Чт мар 20, 2025 10:22 am
nameserver 8.8.8.8
#nameserver 1.1.1.1
#nameserver 8.8.8.8
#nameserver 1.1.1.1
#search .
А файл не трогал:
search .
Отредактируйте файл /etc/resolv.conf
и оставьте только одну строку nameserver 8.8.8.8 и все.
После перезагрузки сервера, в /etc/resolv.conf прописуются значения которые прописаны по умолчанию к конфигах сетевого интерфейса.
Зачем вы редактируете /run/systemd/resolve/resolv.conf ?
ivanpetrov
Сообщение ivanpetrov » Чт мар 20, 2025 10:23 am
Потому что У меня нет такого файла /etc/resolv.conf. Есть но он просто ярлык, и перекидывает на папку /run/systemd/resolve/
Сообщение alenka » Чт мар 20, 2025 10:25 am
ls -al /etc/resolv.conf
Какая у вас ос?
echo 'nameserver 8.8.8.8' > /etc/resolv.conf
ivanpetrov
Сообщение ivanpetrov » Чт мар 20, 2025 10:28 am
root@thishosting:~# ls -al /etc/resolv.conf
lrwxrwxrwx 1 root root 39 Apr 23 2024 /etc/resolv.conf -> ../run/systemd/resolve/stub-resolv.conf
Ubuntu server 24.04
Сообщение alenka » Чт мар 20, 2025 10:33 am
после этой команды у вас заработало ?
