Dovecot засоряет лог
pomoyka
Сообщение pomoyka » Чт янв 18, 2024 2:01 pm
var/log/fail2ban.log alma 9.3
[919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:26:43,764 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:27:43,763 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:28:43,766 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:29:43,616 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:30:43,764 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:31:43,764 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:32:43,505 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:33:43,767 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:34:43,768 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:35:43,766 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:36:43,766 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:37:43,509 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:38:43,764 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:39:43,769 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:40:43,774 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:41:43,770 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:42:43,767 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:43:43,764 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:44:43,677 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:45:43,764 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:46:43,765 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:47:43,508 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:48:43,766 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:49:43,737 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:50:43,630 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:51:43,764 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:52:43,764 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:53:43,768 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:54:43,777 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:55:43,763 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:56:43,772 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:57:43,764 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:58:43,764 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 12:59:43,773 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:00:43,771 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:01:43,765 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:02:43,732 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:03:43,765 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:04:43,649 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:05:43,768 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:06:43,775 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:07:43,496 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:08:43,781 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:09:43,765 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:10:43,763 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:11:43,776 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:12:43,772 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:13:43,720 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:14:43,763 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:15:43,768 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:16:43,764 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:17:43,623 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:18:43,700 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:19:43,764 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:20:43,538 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-01-17 13:21:43,764 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
Как отключить ведение данной записи?
Re: Dovecot засоряет лог
Сообщение alenka » Вт янв 23, 2024 11:46 am
Только что проверила на alma9.3, я не вижу данной проблемы. Проверьте сетевые настройки, в частности ipv6
pomoyka
Сообщение pomoyka » Пт фев 09, 2024 9:45 pm
Alma 9.3 то же самое
2024-02-09 16:37:24,644 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:37:55,895 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:38:25,643 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:38:55,892 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:39:26,653 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:39:55,892 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:40:27,449 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:40:55,890 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:41:28,647 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:41:55,893 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:42:29,641 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:42:55,905 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:43:30,647 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:43:55,904 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:44:31,640 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:44:55,894 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:45:32,403 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:45:55,898 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:46:33,671 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:46:55,893 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:47:34,251 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:47:55,916 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:48:35,641 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:48:55,756 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:49:36,642 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:49:55,904 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:50:37,651 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:50:55,893 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:51:38,641 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:51:55,896 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:52:39,647 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:52:55,891 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:53:40,653 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
2024-02-09 16:53:55,892 fail2ban.filter [919]: INFO [dovecot] Ignore ::1 by ignoreself rule
