Добавлено: Вт дек 10, 2024 8:29 am
				Здравствуйте, перестали генерироваться сертификаты Lets Encrypt.
OS : Ubuntu 22.04
Brainycp : 1.0968.20240911
При попытки сгенерировать сертификат для поддомена вылетает ошибка
			OS : Ubuntu 22.04
File "/usr/bin/certbot", line 33, in
sys.exit(load_entry_point('certbot==1.21.0', 'console_scripts', 'certbot')())
File "/usr/bin/certbot", line 25, in importlib_load_entry_point
return next(matches).load()
File "/usr/lib/python3.10/importlib/metadata/__init__.py", line 171, in load
module = import_module(match.group('module'))
File "/usr/lib/python3.10/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "", line 1050, in _gcd_import
File "", line 1027, in _find_and_load
File "", line 1006, in _find_and_load_unlocked
File "", line 688, in _load_unlocked
File "", line 883, in exec_module
File "", line 241, in _call_with_frames_removed
File "/usr/lib/python3/dist-packages/certbot/main.py", line 2, in
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 18, in
import zope.component
File "/usr/lib/python3/dist-packages/zope/component/__init__.py", line 22, in
from zope.component.interfaces import ComponentLookupError
File "/usr/lib/python3/dist-packages/zope/component/interfaces.py", line 18, in
from zope.interface import implements
ImportError: cannot import name 'implements' from 'zope.interface' (/usr/local/lib/python3.10/dist-packages/zope/interface/__init__.py)
