Clamav Ubuntu обновления
Добавлено: Пт апр 21, 2023 1:18 pm
				ERROR: /var/log/clamav/freshclam.log is locked by another process
Обновление завершено
Решил попробовать так
sudo systemctl stop clamav-freshclam.service
sudo freshclam
итог
Fri Apr 21 16:14:37 2023 -> ClamAV update process started at Fri Apr 21 16:14:37 2023
Fri Apr 21 16:14:37 2023 -> ^FreshClam previously received error code 429 or 403 from the ClamAV Content Delivery Network (CDN).
Fri Apr 21 16:14:37 2023 -> This means that you have been rate limited or blocked by the CDN.
Fri Apr 21 16:14:37 2023 -> 1. Verify that you're running a supported ClamAV version.
Fri Apr 21 16:14:37 2023 -> See https://docs.clamav.net/faq/faq-eol.html for details.
Fri Apr 21 16:14:37 2023 -> 2. Run FreshClam no more than once an hour to check for updates.
Fri Apr 21 16:14:37 2023 -> FreshClam should check DNS first to see if an update is needed.
Fri Apr 21 16:14:37 2023 -> 3. If you have more than 10 hosts on your network attempting to download,
Fri Apr 21 16:14:37 2023 -> it is recommended that you set up a private mirror on your network using
Fri Apr 21 16:14:37 2023 -> cvdupdate (https://pypi.org/project/cvdupdate/) to save bandwidth on the
Fri Apr 21 16:14:37 2023 -> CDN and your own network.
Fri Apr 21 16:14:37 2023 -> 4. Please do not open a ticket asking for an exemption from the rate limit,
Fri Apr 21 16:14:37 2023 -> it will not be granted.
Fri Apr 21 16:14:37 2023 -> ^You are still on cool-down until after: 2023-04-22 12:28:32
Есть рабочее решение?
sudo freshclam
итог
