Проблема почты SquirrelMail
Добавлено: Пт июн 29, 2018 7:38 am
				Кто знает, почему ошибка возникает с кодировкой.
Strict Standards: Non-static method Message::parseStructure() should not be called statically in /usr/share/squirrelmail/functions/mime.php on line 36
Strict Standards: Non-static method Message::parseBodyStructure() should not be called statically in /usr/share/squirrelmail/class/mime/Message.class.php on line 296
Warning: Creating default object from empty value in /usr/share/squirrelmail/class/mime/Message.class.php on line 367
Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /usr/share/squirrelmail/functions/decode/utf_8.php on line 78
Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /usr/share/squirrelmail/functions/decode/utf_8.php on line 83
Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /usr/share/squirrelmail/functions/decode/utf_8.php on line 88
