Неудачное соединение с IMAP сервером
Добавлено: Вт апр 20, 2021 2:38 pm
				Здравствуйте!
Не могу настроить почтовый клиент. Что Roundcube, что Squiremail, бьют ошибку соединения с IMAP сервером. Буду очень благодарен, если подскажете как это дело пофиксить.
Ниже прикреплю логи по командам:
rpm -qa | grep dovecot
systemctl status dovecot
netstat -plunt | grep dovecot
[root@localhost ~]# rpm -qa | grep dovecot
dovecot-2.3.10-1.brainy.el8.x86_64
[root@localhost ~]# systemctl status dovecot
● dovecot.service - Dovecot IMAP/POP3 email server
   Loaded: loaded (/usr/lib/systemd/system/dovecot.service; enabled; vendor preset: disabled)
   Active: active (running) since Tue 2021-04-20 16:49:52 EEST; 45min ago
     Docs: man:dovecot(1)
           http://wiki2.dovecot.org/
 Main PID: 1822973 (dovecot)
    Tasks: 11 (limit: 10988)
   Memory: 11.6M
      CPU: 1.079s
   CGroup: /system.slice/dovecot.service
           ├─1822973 /usr/sbin/dovecot -F
           ├─1823011 dovecot/pop3-login
           ├─1823013 dovecot/anvil
           ├─1823014 dovecot/log
           ├─1823015 dovecot/pop3-login
           ├─1823016 dovecot/pop3-login
           ├─1823018 dovecot/imap-login
           ├─1823019 dovecot/config
           ├─1823021 dovecot/stats
           ├─1898550 dovecot/imap-login
           └─1898943 dovecot/imap-login
Apr 20 17:35:02 localhost.localdomain dovecot[1823014]: pop3-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1823011, input bytes=0
Apr 20 17:35:02 localhost.localdomain dovecot[1823014]: pop3-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1823015, input bytes=0
Apr 20 17:35:02 localhost.localdomain dovecot[1823014]: auth: Fatal: sql: Unknown database driver 'mysql'
Apr 20 17:35:02 localhost.localdomain dovecot[1822973]: master: Error: service(auth): command startup failed, throttling for 60.000 secs
Apr 20 17:35:37 localhost.localdomain dovecot[1823014]: imap-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1898943, input bytes=0
Apr 20 17:35:37 localhost.localdomain dovecot[1823014]: pop3-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1823011, input bytes=0
Apr 20 17:35:37 localhost.localdomain dovecot[1823014]: pop3-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1823016, input bytes=0
Apr 20 17:35:37 localhost.localdomain dovecot[1823014]: pop3-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1823015, input bytes=0
Apr 20 17:35:37 localhost.localdomain dovecot[1823014]: imap-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1898550, input bytes=0
Apr 20 17:35:37 localhost.localdomain dovecot[1823014]: imap-login: Error: auth-client: conn unix:login (pid=1822973,uid=0): Timeout waiting for handshake from auth server. my pid=1823018, input bytes=0
[root@localhost ~]# netstat -plunt | grep dovecot
tcp        0      0 0.0.0.0:110             0.0.0.0:*               LISTEN      1822973/dovecot
tcp        0      0 0.0.0.0:143             0.0.0.0:*               LISTEN      1822973/dovecot
tcp        0      0 0.0.0.0:993             0.0.0.0:*               LISTEN      1822973/dovecot
tcp        0      0 0.0.0.0:995             0.0.0.0:*               LISTEN      1822973/dovecot
tcp6       0      0 :::110                  :::*                    LISTEN      1822973/dovecot
tcp6       0      0 :::143                  :::*                    LISTEN      1822973/dovecot
tcp6       0      0 :::993                  :::*                    LISTEN      1822973/dovecot
tcp6       0      0 :::995                  :::*                    LISTEN      1822973/dovecot
