Не устанавливается MySQL 8.0
Добавлено: Чт июл 09, 2020 5:27 am
				Со свежеустановленной BrainyCP
Starting install MySQL MySql8.0
Install MySQL MySql8.0
Starting find Version
Determining fastest mirrors
Resolving Dependencies
--> Running transaction check
---> Package dovecot-mysql80.x86_64 1:2.2.27-10.el7.centos will be installed
--> Processing Dependency: libmysqlclient.so.21(libmysqlclient_21.0)(64bit) for package: 1:dovecot-mysql80-2.2.27-10.el7.centos.x86_64
--> Processing Dependency: libmysqlclient.so.21()(64bit) for package: 1:dovecot-mysql80-2.2.27-10.el7.centos.x86_64
---> Package exim-mysql80.x86_64 0:4.92.3-1.el7 will be installed
---> Package mysql80-server.x86_64 0:8.0.13-201.brainy.el7 will be installed
--> Processing Dependency: mysql80(x86-64) = 8.0.13-201.brainy.el7 for package: mysql80-server-8.0.13-201.brainy.el7.x86_64
--> Processing Dependency: libmecab.so.2()(64bit) for package: mysql80-server-8.0.13-201.brainy.el7.x86_64
--> Processing Dependency: liblz4.so.1()(64bit) for package: mysql80-server-8.0.13-201.brainy.el7.x86_64
---> Package mecab.x86_64 0:0.996-1.el7.centos.8 will be installed
---> Package mysql80.x86_64 0:8.0.13-201.brainy.el7 will be installed
--> Processing Dependency: liblz4.so.1()(64bit) for package: mysql80-8.0.13-201.brainy.el7.x86_64
---> Package mysql80-libs.x86_64 0:8.0.13-201.brainy.el7 will be installed
Error: Package: mysql80-8.0.13-201.brainy.el7.x86_64 (myrepo-centos)
Requires: liblz4.so.1()(64bit)
Error: Package: mysql80-server-8.0.13-201.brainy.el7.x86_64 (myrepo-centos)
** Found 2 pre-existing rpmdb problem(s), 'yum check' output follows:
clamav-0.101.0-2.4.el7.centos.x86_64 has missing requires of clamav-db
clamav-lib-0.101.0-2.4.el7.centos.x86_64 has missing requires of clamav-db = ('0', '0.101.0', '2.4.el7.centos')Starting postinstall
