Страница 1 из 4
				yum update не работает после установки панели
				Добавлено: Чт авг 16, 2018 4:46 pm
				 dmitry_stas
Чистый Centos 7, ставлю панель
yum clean all && yum install -y wget && wget http://core.brainycp.com/install.sh && bash ./install.sh --package=apache2.4,nginx,php56w,php72w,bindserver,imagemagick,certbot,logrotate,MariaDB10.2,phpMyAdmin-4.7.0,exim,proftpd,csf
установка проходит без ошибок, панель и службы работают. Но далее при выполнении yum update получаю кучу ошибок про зависимость libz.so, типа
Error: Package: rpm-python-4.11.3-32.el7.x86_64 (@anaconda)
           Requires: libz.so.1()(64bit)
           Removing: zlib-1.2.11-8.el7.x86_64 (@myrepo-centos)
               libz.so.1()(64bit)
           Updated By: zlib-1.2.11-8.el7.centos.i686 (myrepo-centos)
               Not found
           Available: zlib-1.2.7-17.el7.x86_64 (base)
               libz.so.1()(64bit)
и так по всем пакетам. Куда копать?
				Re: yum update не работает после установки панели
				Добавлено: Чт авг 16, 2018 6:29 pm
				 dmitry_stas
				попробовал сделать
получаю ошибку
 zlib-1.2.11-8.el7.centos.i686 from myrepo-centos
Error:  Multilib version problems found. This often means that the root
       cause is something else and multilib version checking is just
       pointing out that there is a problem. Eg.:
         1. You have an upgrade for nss-softokn-freebl which is missing some
            dependency that another package requires. Yum is trying to
            solve this by installing an older version of nss-softokn-freebl of the
            different architecture. If you exclude the bad architecture
            yum will tell you what the root cause is (which package
            requires what). You can try redoing the upgrade with
            --exclude nss-softokn-freebl.otherarch ... this should give you an error
            message showing the root cause of the problem.
         2. You have multiple architectures of nss-softokn-freebl installed, but
            yum can only see an upgrade for one of those architectures.
            If you don't want/need both architectures anymore then you
            can remove the one with the missing update and everything
            will work.
         3. You have duplicate versions of nss-softokn-freebl installed already.
            You can use "yum check" to get yum show these errors.
       ...you can also use --setopt=protected_multilib=false to remove
       this checking, however this is almost never the correct thing to
       do as something else is very likely to go wrong (often causing
       much more problems).
       Protected multilib versions: nss-softokn-freebl-3.34.0-2.el7.i686 != nss-softokn-freebl-3.36.0-5.el7_5.x86_64
				Добавлено: Чт авг 16, 2018 7:24 pm
				 dmitry_stas
				Вот если нужно полный лог, который выводит yum update сразу после установки панели
https://www.dropbox.com/s/whsqji4rnga5m ... s.log?dl=0
				Добавлено: Пт авг 17, 2018 3:11 pm
				Аналогичная проблема, из-за которой "упал" сервер!!!
После установки панели, обновление системы не работает!
				Добавлено: Сб авг 18, 2018 8:09 am
				 dmitry_stas
				уже работает. я так понимаю добавили пакет в репу?
				Добавлено: Пн сен 09, 2019 6:13 am
				 dmitry_stas
				Апну тему. Снова получаю ошибку при yum update, на одном сервере такую
Error: Package: cloud-init-18.2-1.el7.centos.2.x86_64 (@updates)
           Requires: pyserial
           Removing: pyserial-2.6-6.el7.noarch (@base)
               pyserial = 2.6-6.el7
           Obsoleted By: python2-pyserial-3.4-1.el7.noarch (myrepo-centos)
               Not found
** Found 1 pre-existing rpmdb problem(s), 'yum check' output follows:
fail2ban-0.9.7-10.el7.centos.noarch has missing requires of fail2ban-sendmail = ('0', '0.9.7', '10.el7.centos')
на другом такую
           Requires: pyserial
               Not found
				Добавлено: Вт сен 10, 2019 9:42 am
				 interstudent
				Удалось побороть?
				Добавлено: Вт сен 10, 2019 6:37 pm
				dmitry_stas писал(а): ↑Пн сен 09, 2019 6:13 am
           Requires: pyserial
               Not found
на другом такую
           Requires: pyserial
               Not found
такой же прикол
вот так обновляюсь теперь =)
yum update --skip-broken
				Добавлено: Ср сен 11, 2019 1:23 pm
				исправлено
yum update
				Добавлено: Ср сен 11, 2019 3:57 pm
				sbury писал(а): ↑Ср сен 11, 2019 1:23 pm
исправлено
yum update
спасибо
