Ошибка генерации сертификата.
Добавлено: Вт апр 22, 2025 6:12 am
				Ошибка генерации сертификата. Серверный хостнейм должен быть привязан к айпи сервера!
Requesting a certificate for site.site
Certbot failed to authenticate some domains (authenticator: webroot). The Certificate Authority reported these problems:
Domain: site.site
Type: unauthorized
Detail: xx.xx.xx.xx: Invalid response from http://site.site/.well-known/acme-chall ... FhF5tRL54w: 403
Hint: The Certificate Authority failed to download the temporary challenge files created by Certbot. Ensure that the listed domains serve their content from the provided --webroot-path/-w and that files created there can be downloaded from the internet.
Some challenges have failed.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
dig @1.1.1.1 site.site A
; <<>> DiG 9.11.3-1ubuntu1.18-Ubuntu <<>> @1.1.1.1 site.site A
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 8651
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1232
;; QUESTION SECTION:
;h1.wilda.ru. IN A
;; ANSWER SECTION:
site.site. 3600 IN A xx.xx.xx.xx
;; Query time: 116 msec
;; SERVER: 1.1.1.1#53(1.1.1.1)
;; WHEN: Tue Apr 22 06:07:09 UTC 2025
;; MSG SIZE rcvd: 56
A
Помогите пожалуйста разобраться. Не хочет сертификат генерироваться для панели. По dns записям все ок, права на папку даже 777 дал, толку ноль.
Invalid response from http://site.site/.well-known/acme-challenge/...: 403
Связка apache+nginx+nodejs+django
Domain: site.site
Type: unauthorized
; (1 server found)
;; Got answer:
;h1.wilda.ru. IN A
;; ANSWER SECTION:
A
