После обновления упал ngix
Добавлено: Ср июл 10, 2024 8:48 am
				.0966 2024-07-01
alma 9.4
Запуск неуспешный
× nginx.service - The nginx HTTP and reverse proxy server
Loaded: loaded (/usr/lib/systemd/system/nginx.service; enabled; preset: disabled)
Drop-In: /usr/lib/systemd/system/nginx.service.d
└─10-limit.conf
Active: failed (Result: exit-code) since Wed 2024-07-10 11:47:02 MSK; 22ms ago
Process: 10735 ExecStartPre=/usr/bin/rm -f /run/nginx.pid (code=exited, status=0/SUCCESS)
Process: 10767 ExecStartPre=/usr/sbin/nginx -t (code=exited, status=1/FAILURE)
CPU: 59ms
Jul 10 11:47:02 .su systemd[1]: Starting The nginx HTTP and reverse proxy server...
Jul 10 11:47:02 .su nginx[10767]: nginx: [emerg] "modsecurity_rules_file" directive Rules error. File: /etc/nginx/modsecurity.conf. Line: 40. Column: 33. As of ModSecurity version 3.0, SecRequestBodyInMemoryLimit is no longer supported. Instead, you can use your web server configurations to control those values. ModSecurity will follow the web server decision. in /etc/nginx/nginx.conf:105
Jul 10 11:47:02 ian.su nginx[10767]: nginx: configuration file /etc/nginx/nginx.conf test failed
Jul 10 11:47:02 ian.su systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE
Jul 10 11:47:02 .su systemd[1]: nginx.service: Failed with result 'exit-code'.
Jul 10 11:47:02 .su systemd[1]: Failed to start The nginx HTTP and reverse proxy server.
			alma 9.4
Запуск неуспешный
└─10-limit.conf
CPU: 59ms
