Apache Error
yuloz
Re: Apache Error
Сообщение yuloz » Пт июл 11, 2025 7:52 am
root@vmi650199:~# apt-get update
Hit:1 http://asi-fs-n.contabo.net/ubuntu focal InRelease
Get:2 http://asi-fs-n.contabo.net/ubuntu focal-updates InRelease [128 kB]
Ign:3 http://46.175.146.57/centos/ubuntu brainycp InRelease
Get:4 http://asi-fs-n.contabo.net/ubuntu focal-backports InRelease [128 kB]
Hit:5 http://46.175.146.57/centos/ubuntu brainycp Release
Ign:6 http://46.175.146.57/centos/ubuntu brainycp Release.gpg
Get:7 http://security.ubuntu.com/ubuntu focal-security InRelease [128 kB]
Get:8 http://asi-fs-n.contabo.net/ubuntu focal-updates/main i386 Packages [1,114 kB]
Get:9 http://asi-fs-n.contabo.net/ubuntu focal-updates/main amd64 Packages [3,954 kB]
Get:10 http://asi-fs-n.contabo.net/ubuntu focal-updates/universe amd64 Packages [1,262 kB]
Get:11 http://asi-fs-n.contabo.net/ubuntu focal-updates/universe i386 Packages [824 kB]
Fetched 7,538 kB in 1s (5,843 kB/s)
Reading package lists... Done
N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'http://46.175.146.57/centos/ubuntu brainycp InRelease' doesn't support architecture 'i386'
root@vmi650199:~#
root@vmi650199:~# apt-get -y install httpd24
Building dependency tree
Reading state information... Done
brotli firebird3.0-common firebird3.0-common-doc gir1.2-freedesktop gir1.2-gdkpixbuf-2.0
gir1.2-rsvg-2.0 icu-devtools javascript-common libblkid-dev libbz2-dev
libcairo-script-interpreter2 libcairo2-dev libcurl3-gnutls libdjvulibre-dev libdpkg-perl
libexif-dev libexif-doc libexif12 libexpat1-dev libfbclient2 libfile-fcntllock-perl
libfontconfig1-dev libfreetype-dev libfreetype6-dev libfuzzy2 libgdk-pixbuf2.0-dev
libglib2.0-bin libglib2.0-dev libglib2.0-dev-bin libice-dev libicu-dev libilmbase-dev
libjansson4 libjbig-dev libjpeg-dev libjpeg-turbo8-dev libjpeg8-dev libjs-jquery liblcms2-dev
libldb2 liblqr-1-0-dev liblzf1 liblzma-dev liblzo2-2 libmagickcore-6-arch-config
libmagickcore-6-headers libmagickcore-6.q16-dev libmagickwand-6-headers libmagickwand-6.q16-dev
libmagickwand-dev libmodsecurity3 libmount-dev libopenexr-dev libpcre16-3 libpcre2-16-0
libpcre2-32-0 libpcre2-dev libpcre2-posix2 libpcre3-dev libpcre32-3 libpcrecpp0v5
libpixman-1-dev libpng-dev libpng-tools libpthread-stubs0-dev libqdbm14 librecode0 librsvg2-dev
libselinux1-dev libsepol1-dev libsm-dev libsmbclient libsnmp-base libsnmp35 libssl-dev
libssl1.0.0 libtalloc2 libtevent0 libtiff-dev libtiffxx5 libtommath1 libwbclient0 libwmf-dev
libx11-dev libxau-dev libxcb-render0-dev libxcb-shm0-dev libxcb1-dev libxdmcp-dev libxext-dev
libxml2-dev libxmlrpc-epi0 libxrender-dev libxt-dev libyajl2 pkg-config python3-ldb
python3-talloc samba-libs shtool snmp uuid-dev x11proto-core-dev x11proto-dev x11proto-xext-dev
xorg-sgml-doctools xtrans-dev zlib1g-dev
Use 'apt autoremove' to remove them.
The following additional packages will be installed:
httpd24-filesystem httpd24-tools
The following NEW packages will be installed:
httpd24 httpd24-filesystem httpd24-tools
0 upgraded, 3 newly installed, 0 to remove and 291 not upgraded.
Need to get 1,415 kB of archives.
After this operation, 6,734 kB of additional disk space will be used.
Get:1 http://46.175.146.57/centos/ubuntu brainycp/main amd64 httpd24-tools amd64 2.4.54-2.4 [55.2 kB]
Get:2 http://46.175.146.57/centos/ubuntu brainycp/main amd64 httpd24-filesystem amd64 2.4.54-2.4 [1,676 B]
Get:3 http://46.175.146.57/centos/ubuntu brainycp/main amd64 httpd24 amd64 2.4.54-2.4 [1,358 kB]
Fetched 1,415 kB in 0s (6,900 kB/s)
Selecting previously unselected package httpd24-tools.
(Reading database ... 125686 files and directories currently installed.)
Preparing to unpack .../httpd24-tools_2.4.54-2.4_amd64.deb ...
Unpacking httpd24-tools (2.4.54-2.4) ...
Selecting previously unselected package httpd24-filesystem.
Preparing to unpack .../httpd24-filesystem_2.4.54-2.4_amd64.deb ...
Unpacking httpd24-filesystem (2.4.54-2.4) ...
Selecting previously unselected package httpd24.
Preparing to unpack .../httpd24_2.4.54-2.4_amd64.deb ...
Unpacking httpd24 (2.4.54-2.4) ...
Setting up httpd24-filesystem (2.4.54-2.4) ...
Setting up httpd24-tools (2.4.54-2.4) ...
Setting up httpd24 (2.4.54-2.4) ...
Configuration file '/etc/httpd/conf/httpd.conf'
==> File on system created by you or by a script.
==> File also in package provided by package maintainer.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer's version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : start a shell to examine the situation
The default action is to keep your current version.
*** httpd.conf (Y/I/N/O/D/Z) [default=N] ? y
Installing new version of config file /etc/httpd/conf/httpd.conf ...
Configuration file '/etc/httpd/conf/httpd_mpm.conf'
*** httpd_mpm.conf (Y/I/N/O/D/Z) [default=N] ? y
Installing new version of config file /etc/httpd/conf/httpd_mpm.conf ...
Processing triggers for libc-bin (2.31-0ubuntu9.9) ...
https://prnt.sc/PD8UypgiQ7Zz
Re: Apache Error
Сообщение alenka » Пт июл 11, 2025 8:54 am
Что то мне кажется что в терминале висит диалоговое окно ожидания, перегрузите сервер, потом переустановите связку.
Re: Apache Error
Сообщение sbury » Пт июл 11, 2025 11:01 am
Удалите отсюда все файлы конфигурации
/etc/httpd/conf/*
Потом переустановите связку. Вы должны обновить панель до последней версии иначе будете иметь такого рода проблемы
