Пропал доступ к панели!
Slava1980
Сообщение Slava1980 » Сб мар 01, 2025 1:06 pm
Сайты работают но в панель не могу зайти ни как.
http://ip:8002 и https://ip:8000 и 127.0.0.1:8002 и 127.0.0.1:8002
перебрасывает на страницу :8002/nolicense.php и пишет ERR_TOO_MANY_REDIRECTS
ОС - Centos 7
systemctl status nginxb
Active: active (running) since Сб 2025-03-01 18:19:06 +07; 1h 21min ago
Process: 52471 ExecStart=/usr/sbin/nginxb (code=exited, status=0/SUCCESS)
Process: 52468 ExecStartPre=/usr/sbin/nginxb -t (code=exited, status=0/SUCCESS)
Process: 52466 ExecStartPre=/usr/bin/rm -f /run/nginxb.pid (code=exited, status=0/SUCCESS)
Main PID: 52473 (nginxb)
Tasks: 3
Memory: 7.0M
├─52473 nginx: master process /usr/sbin/nginxb
├─52474 nginx: worker process
└─52475 nginx: cache manager process
мар 01 18:19:06 slavammm.colo systemd[1]: Starting The nginx HTTP and reverse proxy server...
мар 01 18:19:06 slavammm.colo nginxb[52468]: nginx: [warn] the "ssl" directive is deprecated, use t...nf:9
мар 01 18:19:06 slavammm.colo nginxb[52468]: nginx: the configuration file /usr/local/brainycp/src/...s ok
мар 01 18:19:06 slavammm.colo nginxb[52468]: nginx: configuration file /usr/local/brainycp/src/comp...sful
мар 01 18:19:06 slavammm.colo nginxb[52471]: nginx: [warn] the "ssl" directive is deprecated, use t...nf:9
мар 01 18:19:06 slavammm.colo systemd[1]: Started The nginx HTTP and reverse proxy server.
Active: active (running) since Сб 2025-03-01 18:38:16 +07; 1h 6min ago
Main PID: 57257 (php-fpm)
Status: "Processes active: 0, idle: 6, Requests: 122, slow: 0, Traffic: 0req/sec"
Tasks: 7
Memory: 80.8M
├─ 3396 php-fpm: pool brainy.conf
├─ 3723 php-fpm: pool brainy.conf
├─ 4742 php-fpm: pool brainy.conf
├─ 7488 php-fpm: pool brainy.conf
├─57257 php-fpm: master process (/usr/local/brainycp/src/compiled/php5/php-fpm.conf)
├─57263 php-fpm: pool brainyservice.conf
└─57264 php-fpm: pool brainyservice.conf
мар 01 18:38:16 slavammm.colo systemd[1]: Starting The Brainy-FPM PHP Process Manager...
мар 01 18:38:16 slavammm.colo systemd[1]: Started The Brainy-FPM PHP Process Manager.
Как восстановить доступ?
Re: Пропал доступ к панели!
Сообщение sbury » Пн мар 03, 2025 11:14 am
Попробуйте остановить csf, если он используется а так же полностью iptables
systemctl stop iptables
Slava1980
Сообщение Slava1980 » Пн мар 03, 2025 12:19 pm
Добрый день!
Спасибо! Помогло перегрузить scf.
Но на сервер идет большое количества SYN_RECEIVED запросов.
Как их можно эффективно блокировать ?
Slava1980
Сообщение Slava1980 » Пн мар 03, 2025 2:32 pm
Почитал. Поменял в Cent os
net.ipv4.tcp_synack_retries = 1
net.ipv4.tcp_syn_retries = 1
Количество SYN_RECEIVED сократилось примерно до 10-20.
Проблем с доступом к панели нет.
