certbot не устанавливается
despjke
Сообщение despjke » Ср фев 01, 2023 5:26 pm
В обще не устанавливается certbot, в чём может быть проблема ? Сильно не пинайте, я не гуру.
Вот лог
Installing:
 certbot                   noarch 1.11.0-3.brainy.el7   brainy-python3_sb  33 k
Installing for dependencies:
 audit-libs-python         x86_64 2.8.5-8.el7           myrepo-centos      75 k
 checkpolicy               x86_64 2.5-8.el7             base              295 k
 libcgroup                 x86_64 0.41-21.el7           base               66 k
 libsemanage-python        x86_64 2.5-14.el7            base              113 k
 policycoreutils-python    x86_64 2.5-34.el7            base              457 k
 python-IPy                noarch 0.75-6.el7            base               32 k
 python3-Cython            x86_64 0.28.6-1.el7          brainy-python3_sb 3.3 M
 python3-acme              noarch 1.11.0-3.brainy.el7   brainy-python3_sb  76 k
 python3-asn1crypto        noarch 1.3.0-2.el7           myrepo-centos     181 k
 python3-atomicwrites      noarch 1.3.0-2.el7           brainy-python3_sb  15 k
 python3-attrs             noarch 18.2.0-2.el7          brainy-python3_sb  58 k
 python3-certbot           noarch 1.11.0-3.brainy.el7   brainy-python3_sb 375 k
 python3-certbot-dns-cloudflare
                           noarch 1.12.0-2.brainy.el7   brainy-python3_sb  20 k
 python3-cffi              x86_64 1.11.5-7.1.el7        brainy-python3_sb 226 k
 python3-chardet           noarch 3.0.4-9.el7           myrepo-centos     191 k
 python3-cloudflare        noarch 2.1.0-12.brainy.el7   brainy-python3_sb  52 k
 python3-configargparse    noarch 0.14.0-5.brainy.el7   brainy-python3_sb  29 k
 python3-configobj         noarch 5.0.6-15.brainy.el7   myrepo-centos      58 k
 python3-cryptography      x86_64 2.1.4-1.el7           myrepo-centos     515 k
 python3-distro            noarch 1.3.0-5.brainy.el7    myrepo-centos      29 k
 python3-future            noarch 0.17.1-0.3.brainy.el7 brainy-python3_sb 770 k
 python3-idna              noarch 2.8-1.el7             myrepo-centos      99 k
 python3-josepy            noarch 1.2.0-2.brainy.el7    myrepo-centos      89 k
 python3-linecache2        noarch 1.0.0-19.el7          brainy-python3_sb  13 k
 python3-mock              noarch 2.0.0-14.el7          brainy-python3_sb 130 k
 python3-ndg_httpsclient   noarch 0.4.0-14.brainy.el7   myrepo-centos      46 k
 python3-numpy             x86_64 1:1.14.1-2.el7        brainy-python3_sb 3.5 M
 python3-olefile           noarch 0.46-2.el7            myrepo-centos      53 k
 python3-parsedatetime     noarch 2.4-10.brainy.el7     brainy-python3_sb  74 k
 python3-pathlib2          noarch 2.3.4-3.brainy.el7    brainy-python3_sb  37 k
 python3-pbr               noarch 5.1.2-4.el7           brainy-python3_sb  85 k
 python3-pillow            x86_64 5.3.0-1.el7           myrepo-centos     632 k
 python3-py                noarch 1.7.0-4.el7           brainy-python3_sb 196 k
 python3-pyOpenSSL         noarch 17.3.0-3.brainy.el7   myrepo-centos      79 k
 python3-pyasn1            noarch 0.1.9-20.el7          myrepo-centos     102 k
 python3-pycparser         noarch 2.14-16.el7           brainy-python3_sb 144 k
 python3-pyrfc3339         noarch 1.0-12.brainy.el7     myrepo-centos      12 k
 python3-pysocks           noarch 1.6.8-4.el7           myrepo-centos      29 k
 python3-pytz              noarch 2018.5-4.el7          brainy-python3_sb  42 k
 python3-pyyaml            x86_64 5.3-3.brainy.el7      brainy-python3_sb 198 k
 python3-regex             x86_64 2019.05.25-1.el7      myrepo-centos     337 k
 python3-requests          noarch 2.22.0-5.el7          myrepo-centos     120 k
 python3-requests-toolbelt noarch 0.8.0-1.el7           myrepo-centos      82 k
 python3-scandir           x86_64 1.8-2.braainy.el7     myrepo-centos      47 k
 python3-service-identity  noarch 18.1.0-1.el7          epel               25 k
 python3-six               noarch 1.11.0-5.el7          brainy-python3_sb  31 k
 python3-textile           noarch 3.0.4-1.el7           myrepo-centos      64 k
 python3-urllib3           noarch 1.24.3-4.el7          myrepo-centos     173 k
 python3-zope-component    noarch 4.3.0-7.el7           myrepo-centos     119 k
 python3-zope-event        noarch 4.2.0-12.el7          myrepo-centos      15 k
 python3-zope-interface    x86_64 4.4.3-1.el7           myrepo-centos     148 k
 python36-asn1crypto       noarch 0.24.0-7.el7          epel              180 k
 python36-attrs            noarch 17.4.0-4.el7          epel               49 k
 python36-cffi             x86_64 1.9.1-3.el7           epel              219 k
 python36-cryptography     x86_64 2.3-2.el7             epel              509 k
 python36-idna             noarch 2.10-1.el7            epel               99 k
 python36-pyasn1           noarch 0.4.7-1.el7           epel              173 k
 python36-pyasn1-modules   noarch 0.4.7-1.el7           epel              197 k
 python36-pycparser        noarch 2.14-2.el7            epel               95 k
 python36-six              noarch 1.14.0-3.el7          epel               34 k
 setools-libs              x86_64 3.3.8-4.el7           base              620 k
Updating for dependencies:
 audit                     x86_64 2.8.5-8.el7           myrepo-centos     254 k
 audit-libs                x86_64 2.8.5-8.el7           myrepo-centos     101 k
Transaction Summary
Install  1 Package  (+61 Dependent packages)
Upgrade             (  2 Dependent packages)
Total download size: 16 M
Downloading packages:
Delta RPMs disabled because /usr/bin/applydeltarpm not installed.
Total                                               23 kB/s |  16 MB  11:43
Running transaction check
Running transaction test
despjke
Re: certbot не устанавливается
Сообщение despjke » Ср фев 01, 2023 5:27 pm
Я так понимаю Delta RPM не ставится, но не понятно почему.
Сообщение alenka » Ср фев 01, 2023 5:38 pm
У вас подключены сторонние репозитарии, и скорее всего пакеты по зависимостям.
Удаляете репозитарий epel, чистите пакеты которые установились по зависимостям.
Панель не работает со сторонними репозитариями, при установке панели это выделено красным.
